Special renumber
abcInHell
Special renumber
Post by abcInHell »
Hi out there,
I have a little problem: I use AMC quite long right now, and the "movie numbers" weren't really important for me until now.
But now I want to put my Disks in DVD-boxes and need a special renumbering for my current catalogue. Because if I had added some TV series (i.e. 7 disks), AMC just took the next possible number.
For excample:
Right now it looks like this way:
#50 | Some movie | Disks: 1
#51 | TV-series | Disks: 7
#52 | some movie | Disks: 1
I want to change it like this way:
#58 | some movie | Disks: 1
What it should do:
1. Begin with movie number #1
2. Set integer (last_movienumber + Disks_of_last_movienumber)
3. Find next movie (1. +1)
4. Set new Number
Could someone please help me to do a script for it? I tried it already by myself, but I am not skilled enough to do it alone yet.
Thank you very much in advance!!
mfg
Something like that may work:
program Renumber;
  Num, Discs: Integer;
  if Num = 0 then
    Num := 1;
  SetField(fieldNumber, Num);
  Discs := StrToInt(GetField(fieldDiscs), 1);
  Num := Num + Discs;
variables are not reset between movies, so "Num" will keep the last used number.
abcInHell
Post by abcInHell »
Thank you antp for your quick help! :)
Unfortunately it does not work, I get always this error:
ERROR
Script Error in "RENUMBER": type mismatch at line 7
Line 7 is this one: SetField(fieldNumber, Num);
Do you have any idea how to fix this error?
Kind regards
Num is an integer, while fieldNumber needs a string. You have to transform the Num variable into a string. Change line 7 to:
SetField(fieldNumber, IntToStr(Num));
Besides you have to use "fieldDisks" instead of "fieldDiscs".
I wrote that quickly without testing, I missed some things indeed :D
abcInHell
Post by abcInHell »
Thank you very much!!! It just worked like a charm :)
Thank you!
Regards,
