category
Prophet^^
category
Post by Prophet^^ »
any chance of having multiple movie catagories via script?
imdb usually shows more then one category for a movie but the ant movie catalog's get info script seems to only catch one
this also applies to the language
For the moment the program only supports one value for these fields, so the best that could be done is put multiple values in the field like Drama/Science-Fiction or things like that.
But it is not very nice when you want to use the Group-by functionnality, or in the statistics.
alearbo
Post by alearbo »
Do You think you'll improve the prog with this function?
It is planned, but I do not know when I'll do it.
