abcInHell
Posts: 6 Joined: 2008-07-22 22:21:53
Post
by abcInHell » 2008-07-22 22:23:41
Hi there,
i just wanted to know, which programming language is used for those antp-scripts, that I can learn this special one.
regards
Posts: 9797 Joined: 2002-05-30 10:13:07
Post
by antp » 2008-07-23 08:01:10
The scripts use a language very similar to Pascal/Delphi. So if you find some basic tutorial for these language and observe existing scripts, you should be able to find how to write scripts
Armagedon
Posts: 4 Joined: 2008-07-23 07:18:09
Post
by Armagedon » 2008-07-23 08:15:31
the English.chm help file is useful too.
check out the "Script files creation" part
