XML catalog
XML catalog
Is it possible to open the exported catalog in XML using an Internet browser?
Thanks.
Re: XML catalog
You mean in a nice readable way?
Maybe by writing some XSLT file to process the XML but I'm not sure if web browsers handle that.
Re: XML catalog
Thank you.
I took a look but I think I'll give up because it seems too demanding compared to the results I'm aiming for.
Thanks, anyway, for your suggestions.
Fulvio :grinking:
