remove "HTTP/1.1 404 Not Found" message
When using "getpicture" i get "not found" but I woul like to avoid showing message "HTTP/1.1 404 Not Found" and go on in my script.
Is it possible? How can i do? :??:
Thanks.
Re: remove "HTTP/1.1 404 Not Found" message
I'm not sure it is possible, that should be modified in AMC itself. I should have made that better back then, I don't know why I made it show the message rather than just returning it :(
antp wrote: 2023-09-06 12:40:51 I'm not sure it is possible...
Thanks. Could you try to modify the behavior of AMC so that error messages are intercepted by the script and shown or not?
I could, but so many things to do :D
I'll try to not forget doing it next time I do a change in the program
Thanks. Add it to your to-do-list. :clapping:
Have you found a solution for the problem? is it possible "intercept and manage" "HTTP/1.1 404 Not Found" error? :??:
thanks! :innocent: :innocent:
It is still on my to-do list but I haven't worked on AMC since ;)
(currently version is from May 2023, the install was updated only for new scripts)
what a pity! it would be a truly precious thing. Thanks anyway. :cry:
I remember a post from someone who had experienced something like this but I can't find the related post anymore.... ;)
