OFDB script 1.0.12, dont ask for filmname and normal script
gnuffmaster
Post by gnuffmaster »
Hello,
updated versions of the OFDB script.
- Fixed broken import of actors, director and country
- Fixed correct characters in URL
Normal Script update 1.0.12:
http://www.file-upload.net/download-928 ... -.ifs.html
Script update 1.0.12, which dont ask for a filmname:
2nd Script dont ask for a filmname, it uses filmname from title input fields.
There's a minor bug on these scripts, the scripts contain the header/options part twice (it does not affect functionality). And maybe you should combine both scripts (check for title fields first, and if nothing's found ask for title input), so that only one script could be uploaded to the server as 'official' one ;)
Or add an option to decide what to do
gnuffmaster
bad4u wrote:There's a minor bug on these scripts, the scripts contain the header/options part twice (it does not affect functionality). And maybe you should combine both scripts (check for title fields first, and if nothing's found ask for title input), so that only one script could be uploaded to the server as 'official' one ;)
to combine both is a good idea, i only use the one without asking for the title for a long time and so i made the other "normal" version for all, who use that. i'll check that out tomorrow.
OFDb 1.0.13: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
This version adds a new script option 'AskForMovieTitle' to change behaviour of movie title input if Original or Translated Title field got an entry.
gnuffmaster
Thanks, i haven't had the time to insert this option yet.
gnuffmaster
New Version 1.0.14 out with fixed year import.
See here:
viewtopic.php?t=4068
