just started using Ant MM.
I have a large list of movies with the correct IMDB titles but no other fields in excel. I have imported my titles into Ant and want to use the IMDB script to update all movies at ones.... without any user intervention. Currently the script asks me which movies it has found and match my title... with the first one always being correct. Ones imported it also asks me for the title I want to search for even though the title is already in the windows and all I have to do is press ok.
Some way to autoupdate everything without user intervention?
IMDB script, dont ask me which film to choose
On the right side in the scripting menu, double click on "BatchMode" a new window opens and you can choose if the script is supposed to ask every time, if it should pick the first movie available or if it should use the imdb link from the url field.
And if you remove the tick beside "show ressult window" and set "descriptionSelection" to 0 or 2 the program doesn't need any intervention at all.
