Version 4.2.3.3 BUG
MMM
Version 4.2.3.3 BUG
Post by MMM »
Hello.
I´m still using version 4.2.2.2 because the latest one does not work for me:
I only use 2 scripts: IMDB and IMDB (actors Images).
The thing is, the IMDB shows an error when I click on it to add or update a movie:
Script error on ''IMDB'': unit is not found at line 5
Line 5 is this: ''StringUtils1, StringUtils7552;''
The ''Actors Image'' scrip shows the same error but on line 6;
Line 6 is this: ''StringUtils1;''
I copied my catalogs and images to version 4.2.3.3 folder and changed a few preferences inside the program, so it's just like previous version, also corrected their paths, etc.
Any help, please?
Thank you very much
boyerf
Re: Version 4.2.3.3 BUG
Post by boyerf »
Hello,
Check if you have in your AMC directory \scripts the files :
- StringUtils1.pas
- StringUtils7552.pas
This two units are necessary to use IMDB scripts.
MMM
Post by MMM »
Well, they where not there because I took out the ones I THOUGHT I would not need.
...I was wrong... :ha: :shaking:
Thank you very much :D
