Different language in description field...
lemonyx
Post by lemonyx »
Hi all
This is a great program, easy to use as I have no problems, but one. I have checked off English as the language but in the movie description field it's in Spansih. Is there any way to change this.
Other than this again this is a great program, thank you for writing this and sharing it for free.
Chaz
Language setting is for the program itself, not for the movie info.
The language of fields contents depends what you put in it and/or which script you use to get info.
lemonyx
Post by lemonyx »
Thanks for the reply. I just used the F6 key to get the info from the internet, so whatever the default script is used for that. Have not changed any as yet.
Could you reconmend a "script" to use that will fill in with English? I am not familiar with writing code.
TIA
Many people use IMDB script.
If you wish to see only script that download info in English, you can use the "Language filter" button of the toolbar in the script window: click "check none" and then click "EN".
lemonyx
Post by lemonyx »
Thank you very much that works just great.
thanks for your time
Bablorub
Post by Bablorub »
Thanx for the thread i found it useful 2 :)
