Check All / Uncheck All
baby
Post by baby »
Hi!
i'm new to this program.....i need some help... :ha:
is there a way to check all/none films?
something like "Check all" or "Uncheck all"?
I haven't found this options... :??:
Every tome i need to run a script, i have to check and uncheck manually every film in my list.... :/
thanks for your help!
Baby
Checkboxes in the movie list are like a field, some people use it to indicate what movie they have seen, what movie should be included in export, etc.
When running script you can say that you wich to run the script only on selected movies (which is the default setting I think), which is usually only one movie... no need to apply the script to checked movies if you do not especially need that feature.
And though that it is not the solution, to still reply to your question to check or uncheck all movies you can do ctrl+a to select all, then click with right mouse button and "check selected" or "uncheck selected".
baby
Post by baby »
:p thank you!!!
i will follow your suggestion!
bye!
Baby
