How do I download the scripts from your web site?
Antologist
Post by Antologist »
http://update.antp.be/amc/scripts/
What do I have to do to get them into AMC?
You can find the scripts on your /programs/Ant Movie Catalog/scripts/ folder. If you want to install updates from update.antp.be/amc/scripts just copy the new scripts into that folder or run the script 'Update_scripts' from within AMC, as it will download and copy the scripts for you.
As written at the top of the page:
To download a script, click on its link with the right mouse button and select "Save target" or "Save link". Then save the file in the "Scripts" folder where Ant Movie Catalog is installed, eventually overwriting the old script having the same name.
:D
And indeed the "update scripts" script is the easiest solution
Antologist
Thank You, I guess just I looked at what was written and just stared at it.
Tried it and seems to work fine.
:grinking:
Ok, to resolve this post.
