As you know, OFDb-IMDb no longer works because the operators have completely rewritten the website (they call it OFDb 2.0). The search now apparently works via javascript. I don't know how to trigger something like that with an AMC script. I thought about a google search. But I have no idea about that either. Luckily I then found the site ofdb.mobi. You can search with it.
But since OFDb.de has been completely rewritten and there have also been many changes at IMDb, I have rewritten the script altogether and called it OFDb-mobi-IMDb. The search now runs via ofdb.mobi. The data comes - as usual - from ofdb.de and imdb.com and can also be mixed.
If you are interested, I will gladly upload the script. You just have to tell me where.
New Script OFDb-mobi-IMDb
Re: New Script OFDb-mobi-IMDb
Thanks for your work!
I can put it on my server if you want to make it available for others.
Either send it to me via https://ks3c.antp.be/upload.php or put the code here on the forum between [code] [/code] tags
Thanks, it is now available via https://update.antp.be/amc/scripts/ or via the "Update scripts" script.
close-up
Thank you, works fine for me!
