Can I watch my collection on Internet
stevemuller
Post by stevemuller »
I always used dvd profiler wich also can be watched through the internet. Is this also possible with Ant?
Thanks.
One solution is to export the list to HTML and then upload these HTML files to your site.
If you have a more advanced knowledge, you may want to use one of the PHP-based solutions, with either XML or SQL database. For these there are few zipped examples in the Templates folder of the program, and more on the "Templates" section of the forum.
