[REL][ITA] AlCinemaInCasa.it
seraphico
Post by seraphico »
This is the script for www.alcinemaincasa.it i've not tested too much if there's something wrong let me know. :grinking:
Authors=Claudio Rinaldi ( rinaldiclaudio@gmail.com )
Title=AlCinemaInCasa
Description=Get movie info from alcinemincasa.it
Site=www.alcinemaincasa.it
Language=IT
Version=1.0
Requires=3.5.1
Comments=
License=
program AlCinemaInCasaIT;
  Pivlib; // Pivello's scripts common library
  UrlBase = 'http://www.alcinemaincasa.it';
  UrlRicerca = '&ORDER=prodottoasc';
  QueryBase = UrlBase + '/commy/prodotti_lista_public.asp?action=Cerca&TX_CM_PRODOTTO=';
  QueryFilm = UrlBase + '/commy/prodotti_view.asp?PRODOTTO_ID=';
  ImagePath = UrlBase + '/locandine/';
  cStartNumRis = '</span> di ';
  cEndNumRis = '</td>';
  cStartId = 'PRODOTTO_ID=';
  cEndId = '"';
  cStartTitle = 'CommyHeading4';
  cEndTitle = '</h1>';
  cStartTranslTitle = 'Titolo Originale</strong>: ';
  cEndTranslTitle = '</h2>';
  cStartImg = 'CommyThumbsAna" src="';
  cEndImg = '" alt';
  cStartDirector = 'Regista</li>';
  cEndDirector = '</li>';
  cStartCast = 'Attori</li>';
  cEndCast = '</li>';
  cStartCategory = 'Genere</li>';
  cEndCategory = '</li>';
  cStartDuration = 'Durata</li>';
  cEndDuration = '</li>';
  cStartCountry = 'Nazionalità</strong>:';
  cEndCountry = ' ';
  cStartYear = 'Anno di produzione</li>';
  cEndYear = '</li>';
  cStartDesc = '<p class="CommyDesc4">';
  cEndDesc = '</p>';
  cStartTitleList = 'title=';
  cEndTitleList = '</a>';
  MovieUrl, MovieName, TranslatedStr, PageStr:  string;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  cImage,cValue : string;
  // Get packed title main page
  // ORIGINAL TITLE
  SetField(fieldOriginalTitle, GetValueEx(PageStr, cStartTitle, cEndTitle,true,true));
  PageStr := GetPageStr;
  // FILM IMAGE
  cImage := GetValueEx(PageStr, cStartImg, cEndImg, true, false);
  if cImage <> '' then
    GetPicture(cImage);
  // YEAR
  SetField(fieldYear, GetValueEx(PageStr, cStartYear, cEndYear, true, false));
  // ACTORS
  SetField(fieldActors, GetValueEx(PageStr, cStartCast, cEndCast, false, false));
  // DURATION
  SetField(fieldLength, GetValueEx(PageStr, cStartDuration, cEndDuration, true, false));
  // CATEGORY
  cValue := GetValueEx(PageStr, cStartCategory, cEndCategory, true, false);
  SetField(fieldCategory, AnsiUpFirstLetter(AnsiLowerCase(cValue)));
  // DIRECTOR
  SetField(fieldDirector, GetValueEx(PageStr, cStartDirector, cEndDirector, false, false));
  // DESCRIPTION
  SetField(fieldDescription, GetValueEx(PageStr, cStartDesc, cEndDesc, true, false));
  // COMMENTS
  // URL
  SetField(fieldURL, MovieUrl);
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
  cFilmId,cFilmTitle: string;
  StartPos,EndPos: integer;
  if OneFilm then begin
    cFilmId := GetValueEx(PageStr,cStartId,cEndId,false,false);
    result := QueryFilm + cFilmId;
  else begin
      StartPos := pos(cStartId, PageStr);
      if StartPos > 0 then begin
        Delete(PageStr, 1, StartPos - 1);
        cFilmId := GetValueEx(PageStr,cStartId,cEndId,true,false); // Get ID
        cFilmTitle := GetValueEx(PageStr,cStartTitleList,cEndTitleList,true,true); // Get Title
        if cFilmTitle <> '' then
          PickTreeAdd(cFilmTitle, QueryFilm + cFilmId);
        EndPos := pos(cStartId,PageStr);
        Delete(PageStr, 1, EndPos);
    until(StartPos = 0);
    result := '';
// IN:  page Url (string)
// OUT: none
procedure AnalyzeSearchPage(Url: string);
  NumRisultati : string;
  PageStr := RemoveExtraChars(Url);
  NumRisultati := GetValueEx(PageStr, cStartNumRis, cEndNumRis, true, false);
  if ( (NumRisultati = '0') or (NumRisultati = '')) then
      ShowMessage('Title not found / Nessun film trovato.');
  if NumRisultati = '1' then
    MovieUrl := PopulatePickTree(true)
      PopulatePickTree(false);
  AnalyzeMoviePage;
// GET FIELD VALUES FROM PACKED PAGE
// IN:  Start marker     (String)
//      End marker       (string)
//      Cut Start Marker (bool)
//      Cut End Marker   (bool)
// OUT: value            (string)
function GetValueEx(MyPageStr,cStartMarker,cEndMarker: string;bCutEnd,bAdjust: boolean): string;
  StartPos: integer;
  EndPos: integer;
  Value: string;
  Value := '';
  StartPos := pos(cStartMarker, MyPageStr);
  if ( StartPos = 0 ) then exit; // Not found
  StartPos := StartPos + length(cStartMarker);
  Delete(MyPageStr, 1, StartPos -1);
  EndPos := pos(cEndMarker, MyPageStr);
  if EndPos > 0 then begin
    Value := copy(MyPageStr, 0, EndPos-1);
    if bCutEnd then
      EndPos := EndPos + length(cEndMarker);
    Delete(MyPageStr, 1, EndPos -1);
    if bAdjust then
      Value := '<' + Value;
  TmpPageStr := MyPageStr;
  HTMLRemoveTags(Value);
  HTMLDecode(Value);
  result := Trim(Value);
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,5,0) then
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr;
      if(Input('MyMovies.It', 'Enter the title of the movie', MovieName)) then
          InitializePivLib;
          MovieUrl := QueryBase + StringReplace(MovieName,' ','+') + UrlRicerca;
          AnalyzeSearchPage(MovieUrl);
          FinalizePivLib;
The script is not showed between those able to load information from the net pressing (F6)..... is there any mistake in the code? :??:
thanks.
seraphico
Post by seraphico »
I've made a few test and i find that the script is the archive but not in the script dir.
With this situation the updater didn't download the script,
so if you want to use it download it manually from the archive
and put in the script dir on your local drive.
I also think that Antoine can solve this copying the file.
Hope he read us! :D
See you all soon
:grinking:
the script dir as you name it only contains scripts that were updated since the last AMC release, so that's normal.
seraphico
Post by seraphico »
Ok, but why the updater don't get the script?
I've check the header of the script and it seems to be fine...
i've forget something?
Isn't there an option to check in all scripts (including archive) ? Or a link to find all scripts ?
(it is not me who made that so I do not remember exactly :D)
antp wrote:Isn't there an option to check in all scripts (including archive) ? Or a link to find all scripts ?
Sorry... the problem is now solved (but I can't understand what happened) and the script is correctly loaded using F6.
Thank you all (hope you didn't waste too much time) :(
DjDiabolik
Post by DjDiabolik »
The script no more appears from the updater script......... because ?
Because the latest version of the script is included in latest AMC release.
You have to click "find more" or "additional scripts" to see the whole list.
