IMDB Script error - need help
RuN
Post by RuN »
I'm using Vista and AMC v. 3.5.1 and IMDB script v. 3.3.1.
When I try to run the script it shows me an error saying:
>Script Error in "IMDB": unit is not found at line 4<
4th line in thah script is:
StringUtils1;
I've downloaded script from update page (just save as and save it in to the folder of scripts).
Where is the problem??
You need to download StringUtils1.pas and copy it to your scripts folder, too.
http://update.antp.be/amc/scripts/StringUtils1.pas
RuN
Post by RuN »
Thank You. I did'n know that.
Thans again.
