[REL] cinefacts.de FiX
Legion
Post by Legion »
Hello,
here is my simple FiX for the cinefacts.de-Script. Old version shows only 10 results, and contains even uninteresting "Kino" & TV-category.
New one shows all results and only DVD-category.
I just edited a single URL (see at the end of the script at >AnalyzeIndexPage< )
Here is the Code:
Authors=OL
Title=Cinefacts.de
Description=cinfacts.de import incl. Big/small Picture
Site=www.cinefacts.de
Language=DE
Version=v0.1.5 -  06.02.2007
Requires=3.5.0
Comments=based on dvd-inside script by Tiziano Müller||Script Option "BigPicture"  for loading Big / Small Picture |0 = load small picture|1= load big picture||Script Option "PictureOnly" for loading only the picture|without description|0=load picture & description|1=load only picture without description|
License=
BigPicture=1|1|0=import small picture|1=import big picture
PictureOnly=0|0|0=import all|1=import picture only
program CineFactsDE;
  CRLF = #13#10;
  MovieURL: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function MyTrim(str_: string): string;
  chars: array of char;
  StrLen, i, LastSpacePos: integer;
  result := '';
  str_ := StringReplace(str_, #9, '');
  str_ := StringReplace(str_, #10, '');
  str_ := StringReplace(str_, #13, '');
  while Pos(' ', str_) = 1 do
    Delete(str_, Pos(' ', str_), 1);
  StrLen := Length(str_);
  SetArrayLength(chars, StrLen);
  for i := 0 to StrLen-1 do
    chars[i] := Copy(str_,i+1,1);
  str_ := '';
  LastSpacePos := StrLen - 1;
  if LastSpacePos > -1 then
    while chars[LastSpacePos] = ' ' do
      LastSpacePos := LastSpacePos - 1;
    for i:= 0 to LastSpacePos do
      str_ := str_ + chars[i];
  str_ := StringReplace(str_, '  ', ' ');
  while result <> str_ do
    result := str_;
  result := StringReplace(result, ' ,', ',');
procedure CutAfter(var str_: string; Pattern: string);
  str_ := Copy(str_, Pos(Pattern, str_) + Length(Pattern), Length(str_));
function GetStringBetween(str_, StartTag, EndTag: string): string;
  BeginPos, EndPos: integer;
  result := '';
  if EndTag = '' then
    EndPos := Length(str_);
    EndPos := Pos(EndTag, str_);
  BeginPos := Pos(StartTag, str_) + Length(StartTag);
  if StartTag = '' then BeginPos := 1;
  if BeginPos > 0 then result := Copy(str_, BeginPos, EndPos - BeginPos);
function GetTrimmedStringBetween(str_, StartTag, EndTag: string): string;
  result := MyTrim(GetStringBetween(str_, StartTag, EndTag));
// Extracts single movie detail (like director, genre) from page
  Result := '';
  Page := StringReplace(Page, 'ß','ß');
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
//    HTMLRemoveTags(Result);
    HTMLDecode(Result);
function StripHTMLTags(str_: string): string;
  temp_char : char;
  StrLen, i, CharPos : integer;
  DoCopy : boolean;
  DoCopy := true;
  CharPos := 0;
  result := '';
  for i := 1 to StrLen do
    temp_char := Copy(str_,i,1);
    if temp_char = '<' then
      DoCopy := false;
      continue;
    else if temp_char = '>' then
      DoCopy := true;
      continue;
      if DoCopy then
        result := result + temp_char;
procedure AnalyzeIndexPage(Address: string);
  IndexPage: TStringList;
  Page : String;
  IndexPage := TStringList.Create;
  Address := URLEncode(Address);
  IndexPage.Text := GetPage(Address);
  PickTreeAdd('Search results', '');
  AddMoviesTitles(IndexPage);
    Page := GetPage(Address);
    AnalyzeMoviePage(Page, Address);
  IndexPage.Free;
procedure AnalyzeMoviePage(Page, Address :String);
  TomString, Line, Temp, Value: string;
  isKino : Boolean;
  LineNr, IntValue: Integer;
  BeginPos, EndPos: Integer;
  StrPosition: Integer;
  StrTemp,srcPic, MovieID: string;
  OriginalTitle, Country, Year, Genre, Studio, Region, EAN_Number, Distributor, AFK, Duration: string;
  VideoFormat, ScreenFormat, ScreenSystem, Language, AudioFormat, Subtitle, MediaType, Disks: string;
  Comments, Bonusmaterial, Packaging, TranslatedTitle, Director, Cast, Producer, Description: string;
  Music, Screenplay: string;
 if Pos('/kino/', Address) > 0 then isKino := true
 else isKino := false;
if GetOption('PictureOnly') = 0 then
// Initializing the very important Comments
  Comments := '';
// URL
// Translated title
  TranslatedTitle := MyTrim(GetStringFromHTML(Page,'span class="headline">','">','<br>'));
  SetField(fieldTranslatedTitle, TranslatedTitle);
// Original-Title, Country and Year
  if (isKino) then
    OriginalTitle := MyTrim(GetStringFromHTML(Page, 'Originaltitel:','"first">','</dd>'))
  else OriginalTitle := MyTrim(GetStringFromHTML(Page, 'Originaltitel:','"first">','(<a href="'));
  StrTemp := MyTrim(GetStringFromHTML(Page, '"land_list.php?name=','">','</dd>'));
  StrTemp := StripHTMLTags(StrTemp);
  if not (isKino) then StrTemp := GetTrimmedStringBetween(StrTemp,'(',')');
  Country := Copy(StrTemp,1,Length(StrTemp)-4);
  Year := Copy(StrTemp,Length(StrTemp)-4,Length(StrTemp));
  SetField(fieldOriginalTitle, OriginalTitle);
  SetField(fieldCountry, Country);
  SetField(fieldYear, Year);
// EAN-Number
  EAN_Number := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">EAN-Nummer:','', '</dd>')));
  EAN_Number := StringReplace(EAN_Number,'EAN-Nummer:','');
  Comments := Comments + 'EAN-Nummer: ' + EAN_Number + CRLF;
// Genre
  Genre := '';
  Genre := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Genre:', '', '</dd>')));
  Genre := StringReplace(Genre,'Genre: ','');
  setField(fieldCategory, Genre);
// Studio
  Studio := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Studio:','', '</dd>')));
  Studio := StringReplace(Studio,'Studio: ','');
  Comments := Comments + 'Studio: ' + Studio + CRLF;
// Distributor
  Distributor := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Vertrieb:','', '</dd>')));
  Distributor := StringReplace(Distributor,'Vertrieb: ','');
  Comments := Comments + 'Vertrieb: ' + Distributor + CRLF;
// Altersfreigabe
  AFK := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">FSK:','', '</dd>')));
  AFK := StringReplace(AFK,'FSK: ','');
  Comments := Comments + 'Altersfreigabe: ' + AFK + CRLF;
// CountryCode
  Region := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Ländercode:','', '</dd>')));
  Region := StringReplace(Region,'Ländercode: ','');
  VideoFormat := 'DVD Zone '+Region;
  setField(fieldVideoFormat,VideoFormat);
// Duration
  Duration := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Länge:','', '</dd>')));
  Duration := StringReplace(Duration,'Länge: ','');
  Duration := StringReplace(Duration,' Minuten','');
  setField(fieldLength,Duration);
// Description
  if (isKino) then
    Description := GetStringFromHTML(Page, '<li class="c1">','', '</li>')
  else Description := GetStringFromHTML(Page, '<li class="text c1">','', '</li>');
  Description := StringReplace(Description, '<br />','*');
  Description := MyTrim(StripHTMLTags(Description));
  Description := StringReplace(Description, '*',CRLF);
  setField(fieldDescription,Description);
// Actors
  if (isKino) then
    Cast := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Darsteller:','', '</dd>')));
    Cast := StringReplace(Cast,'Darsteller: ','');
    Cast := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Schauspieler:','', '</dd>')));
    Cast := StringReplace(Cast,'Schauspieler: ','');
  setField(fieldActors,Cast);
// Director
  Director := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Regie:','', '</dd>')));
  Director := StringReplace(Director,'Regie: ','');
  setField(fieldDirector,Director);
// Production
  Producer := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Produzent:','', '</dd>')));
  Producer := StringReplace(Producer,'Produzent: ','');
  setField(fieldProducer,Producer);
// Music
  Music := '';
  Music := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Musik:','', '</dd>')));
  Music := StringReplace(Music,'Musik:','');
  Music := StringReplace(Music,' Minuten','');
  Comments := Comments + 'Musik:' + Music + CRLF;
// Screenplay
  Screenplay := '';
  Screenplay := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Drehbuch:','', '</dd>')));
  Screenplay := StringReplace(Screenplay,'Drehbuch: ','');
  Comments := Comments + 'Drehbuch: ' + Screenplay + CRLF;
// Screen format & system
  ScreenFormat := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Format:','', '</dd>')));
  ScreenFormat := StringReplace(ScreenFormat,'Format: ','');
  ScreenSystem := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">System:','', '</dd>')));
  ScreenSystem := StringReplace(ScreenSystem,'System: ','');
  setField(fieldResolution,ScreenSystem + ' - ' + ScreenFormat);
// Audioformat/Language
  AudioFormat := '';
  Language := '';
  StrTemp := GetStringFromHTML(Page, '<dt class="c1">Tonformat:', '', '<dt class="c1">Untertitel:');
  StrTemp := StringReplace(StrTemp, '</dd>','*');
  StrTemp := MyTrim(StripHTMLTags(StrTemp));
  StrTemp := StringReplace(StrTemp,'Tonformat: ','');
  while Pos('*',StrTemp) > 0 do
    AudioFormat := AudioFormat + ', ' + MyTrim(Copy(StrTemp,1,Pos(' in ',StrTemp)));
    Language := Language + ', ' + MyTrim(Copy(StrTemp,Pos(' in ',StrTemp)+4,Pos('*',StrTemp)-(Pos(' in ',StrTemp)+4)));
    CutAfter(StrTemp,'*');
  AudioFormat := Copy(AudioFormat,3,Length(AudioFormat));
  Language := Copy(Language,3,Length(Language));
  setField(fieldAudioFormat, AudioFormat);
  setField(fieldLanguages, Language);
// Subtitles
  Subtitle := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Untertitel:', '', '</dd>')));
  Subtitle := StringReplace(Subtitle,'Untertitel: ','');
  if Subtitle = 'Keine Untertitel' then Subtitle := '';
  setField(fieldSubtitles, Subtitle);
// Mediatype
  MediaType := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Medientyp:','', '</dd>')));
  MediaType := StringReplace(MediaType,'Medientyp: ','');
  setField(fieldMediaType, MediaType);
// Disks
  Disks := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Medienanzahl:','', '</dd>')));
  Disks := StringReplace(Disks,'Medienanzahl: ','');
  setField(fieldDisks, Disks);
// Package
  Packaging := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Verpackung:', '', '</dd>')));
  Packaging := StringReplace(Packaging,'Verpackung:','');
  Comments := Comments + 'Verpackung: ' + Packaging + CRLF;
// Bonusmaterial
  Bonusmaterial := MyTrim(GetStringFromHTML(Page, ' BONUS-MATERIAL </li>', '', '</ul>'));
  Bonusmaterial := StringReplace(Bonusmaterial,'</span>','*');
  Bonusmaterial := StringReplace(Bonusmaterial,'<li>','-');
  Bonusmaterial := MyTrim(StripHTMLTags(Bonusmaterial));
  Bonusmaterial := StringReplace(Bonusmaterial,'BONUS-MATERIAL','');
  Bonusmaterial := StringReplace(Bonusmaterial,'*',CRLF);
  Comments := Comments + CRLF + 'Bonusmaterial' + CRLF + '===========' + CRLF + Bonusmaterial + CRLF;
  setField(fieldComments,Comments);
  if CanSetPicture then
    MovieID := Copy(Address,Pos('?id=',Address)+4,Length(Address));
    if GetOption('BigPicture') = 1 then
        srcPic := 'http://www.cinefacts.de/bild.php?id=' + MovieID + '&type=db&studio=' + StringReplace(Studio,' ','');
        if srcPic = '' then
          srcPic := 'http://www.cinefacts.de/bild.php?id=' + MovieID + '&type=ds&studio=' + StringReplace(Studio,' ','');
    GetPicture(srcPic);
  //DisplayResults;
procedure AddMoviesTitles(ResultsPage: TStringList);
  Page,str_: string;
  sNr,pNr,aPage : Integer;
  MovieTitle, MovieAddress: String;
  Page := ResultsPage.Text;
  snr := 0;
  str_ := MyTrim(StripHTMLTags(GetStringFromHTML(Page, 'Anzahl Ergebnisse gesamt:', '', '</li>')));
  str_ := StringReplace(str_,'Anzahl Ergebnisse gesamt: ','');
  pNr := StrToInt(StringReplace(str_,')',''),1);
  aPage := 1;
  while sNr < pNr do
    while Pos('filmdetails.php?id=', Page) > 0 do
      CutBefore(Page, 'filmdetails.php?id=');
      MovieAddress := 'http://www.cinefacts.de/kino/db/' + GetStringFromHTML(Page, 'filmdetails.php?id=', '', '"');
      MovieTitle := MyTrim(GetStringFromHTML(Page, 'filmdetails.php?id=', '">', '</tr>'));
      MovieTitle := StringReplace(MovieTitle, '</td>', ' | ');
      MovieTitle := MyTrim(StripHTMLTags(MovieTitle));
      CutAfter(Page, '</tr>');
      PickTreeAdd('(Kino) ' + MovieTitle, MovieAddress);
    while Pos('/details.php?id=', Page) > 0 do
      CutBefore(Page, '/details.php?id=');
      MovieAddress := 'http://www.cinefacts.de/dvd/db' + GetStringFromHTML(Page, '/details.php?id=', '', '"');
      MovieTitle := MyTrim(GetStringFromHTML(Page, '/details.php?id=', '">', '</tr>'));
      PickTreeAdd('(DVD) ' + MovieTitle, MovieAddress);
    sNr := sNr + 50;
    aPage := aPage + 1;
    if sNr < pNr then
    Page := GetPage(URLEncode('http://www.cinefacts.de/suche/suche.php?akseite='+IntToStr(aPage)+'&startwert='+IntToStr(sNr)+'&name='+MovieName));
  if CheckVersion(3,5,0) then
    if Input('cinefacts.de Import', 'Filmtitel eingeben:', MovieName) then
      AnalyzeIndexPage('http://www.cinefacts.de/suche/suche.php?type=d&name='+MovieName+'&go.x=0&go.y=0');
Greetings
Legion
Re: [REL] cinefacts.de FiX
Thanks.
abcInHell
Post by abcInHell »
Unfortunately, this script does not work any more, because www.Cinefacts.de changed its direct-links.
Could someone please have a look at this script, and could fix it?
I tried it myself, but I am not skilled enough in programming yet, so I couldn't get it.
Would be pretty nice, if someone helps me out :)
regards
cinefacts.de 0.2.0: http://www.bad4u.741.com/full/cinefacts.de.ifs (copy link into a NEW browser window !)
The old script needed quite a lot of changes, I hope I found all bugs now.. not sure if import of big picture works for all films, as they did some major changes there for new films (it works at least for the old and new ones I tested).
Legion
Post by Legion »
Big THANX!!! :) @ bad4u
Greetings
abcInHell
Post by abcInHell »
Thank you bad4u, good job :)
And if you replace this line with the second one, you will even get the "old" Display-Results look:
      MovieTitle := MyTrim(GetStringFromHTML(Page, 'class="headline">', '">', '</b></a>'));
replace with:
      MovieTitle := MyTrim(GetStringFromHTML(Page, 'class="headline">', '">', '<td class='));
mfg
abcinhell
As I don't use cinefacts.de script, I cannot know about previous look of its results list - I just kept my eye on its functionality ;)
If titles on results list show more details (again), this is for sure an improvement. Feel free to change the code and upload a new version, but please raise version number to 0.2.1 then. Thanks.
If there is just that change to make, I'll do it directly on the site which is on the server, no need of a new version posted here then :)
Usually when it is a script that you fixed I wait for you release the new version, as I thought that you were keeping locally all the scripts that you modified...
But you maybe rely on your local copy only for the "update" script?
Yes, it's just that small change (and it has been tested) ;)
About the other scripts see PM pls.
PM ?
PM ;)
