maxcira
Posts: 7 Joined: 2007-05-10 13:49:07
Post
by maxcira » 2008-03-25 15:09:09
Thank you for the wonderful program!!!!
It will be spectacular have the possibility to do a "search..." about the actors (ex. find in the catalog all the movies played by Richard Gere...)
Posts: 1148 Joined: 2006-12-11 22:54:46
Post
by bad4u » 2008-03-25 16:07:03
This is possible. Open search window (->Tools ->Find). Search in field 'Actors'. Search for 'Richard Gere'. Hit 'Find next'.
If you click on 'Display results' checkbox, AMC will list all and only films with Richard Gere. Spectacular
