Panoramic Movie Template - Modèle Panoramique
Eyael
Post by Eyael »
I have just created a new HTML template which looks rather similar to my previous template based on DVDFr site in structure only. The code has been totally rewritten and improved as well a a new design of course. It looks much better with Firefox since it respects Web standard unlike IE. However I've worked hard to make it as much compatible with IE as possible (at list minimum IE5.5). Hope you enjoy it. Some Javascript is necessary for lists and to load PNG correctly with IE6 as well. This is more than just an HTML template to export your AMC catalogs as I've also included other templates and links to turn it into a movie fan site. Thus a template (that you can use with AMC) will enable you to list most recent additions as a two column table (the trick is it's not really a table, that's why it works!). Other templates to be filled manually will enable you to create an index with your favorite actors or directors while another will create a page with their filmography, biography, etc. Another link you can use to store interviews, articles or create a photo galleries, whatever you like. And the style can be changed anytime just modifying the CSS file and related backgrounds. A HTML help file is included in the Zip and I strongly advise you to read it before starting anything.
Here's what the template looks like with Firefox 2 (screen resolution 1024x768):
And this is how my own site looks like:
Download here: https://forum.antp.be/users/eyael/Eyael ... 008_EN.zip
Eyael
Post by Eyael »
Je viens juste de créer un nouveau modèle HTML assez similaire au précédent basé sur le site DVDFr mais dans sa structure uniquement. J'ai entièrement réécrit le code et je l'ai amélioré et j'ai créé un nouveau design bien sûr. Il s'affichera beaucoup mieux avec Firefox car il respecte les standards du Web, ce qui n'est pas le cas de IE. Toutefois j'ai passé des heures à le rendre le plus compatible possible avec IE (du moins à partir de la version IE5.5). J'espère que vous aimerez. Il a du Javascript pour les listes et également pour que les PNG s'affichent correctement sous IE6. Ceci est bien plus qu'un simple modèle HTML pour exporter vos catalogues AMC car j'ai aussi inclus d'autres modèles et liens pour le transformer en un site de fan de cinéma. Ainsi un modèle (que vous pourrez utiliser avec AMC) vous permettra de lister vos films les plus récents sur un tableau à deux colonnes (l'astuce est qu'il ne s'agit, en fait, pas d'un tableau, c'est pourquoi ça fonctionne!). D'autres modèles, à remplir manuellement, vous permettront de créer un index de vos acteurs ou réalisateurs favoris, un autre vous permettra de générer une page comportant leur filmographie, biographie, etc. Avec un autre lien, vous pourrez mettre des interviews, articles ou bien créér une gallerie de photos, tout ce que vous voudrez. Le style peut être modifié à tout moment via le fichier CSS et les arrière-plans concernés. Un fichier d'aide au format HTML est inclus dans le Zip et je vous conseille vivement de le lire avant toute chose.
Pour les captures voir poste précédent en anglais.
Télécharger ici : https://forum.antp.be/users/eyael/Eyael ... 008_FR.zip
PeNeWaN
Post by PeNeWaN »
I can't understand the help file ... can you make a "tutorial for dummys"? thanks!
Eyael
Post by Eyael »
What is it you don't understand with the tutorial? I've tried to keep as simple as possible, obviously I didn't succeed. I cannot rewrite the tutorial but hopefully I can try and help you understand the points that are obscure to you.
skotu
Post by skotu »
Bonjour ,
d'abord merci pour le formidable logiciel qu'est Ant movie.
Ensuite stp Eyael need help . ça fait une semaine que je me prends la tête sur ton template je n'arrive à rien . J'arrive uniquement à avoir la liste de mes films dans la partie de droite mais dès que je clique la page ne s'affiche pas...
Eyael
Post by Eyael »
Je suis désolée d'apprendre que tu as des problèmes car je l'ai testé et ça marche et je ne suis pas spécialiste de l'informatique! Si tu m'en disais plus déjà je pourrais sans doute mieux t'aider...
Euh tu veux dire la liste des films à gauche (pas à droite)?
Tu as bien exporté les listes de films en plusieurs étapes (modèle List à sélectionner dans AMC) puis les fiches des films (avec modèle Indiv)? Si oui dans ton dossier cible tu as bien toutes les pages HTLM nécessaire? Tu as bien mis les images, les ressources et les différents éléments du site comme indiqué dans le tuto? Par que si tu as changé un nom, un chemin ou quoi ce soit, ça va poser problème. Ça peut se modifier en éditant les modèles. Les listes de films sont dans un dossier différents des pages des films.
Les liens des listes à droite doivent s'ouvrir dans le cadre "main". Est-ce que ton navigateur accepte les jeux de cadres (normalement oui mais un problème de configuration peut le faire).
Merci d'expliquer ce que tu as fait et de détailler comment est ton site pour que je puisse essayer de comprendre ce qui cloche. Si j'ai le temps j'essaierai de faire une version plus simple avec tous les fichiers au même endroit (j'avais fait ce modèle pour mes besoins perso qui ne sont pas forcément ceux de tout le monde ;)
Eyael
Post by Eyael »
Serait-il plus simple si je refaisais le modèle en modifiant les chemins de manière à ce que tout soit dans un dossier unique? J'aurais besoin de vos échos car j'ai beaucoup travaillé pour vous offrir ce modèle et ça n'a aucun intérêt si vous n'arrivez pas à l'utiliser. Donc si vous faites des commentaires, merci d'être le plus précis possible, ça m'aidera grandement à l'améliorer.
Would it be easier if I recompiled the template using a single folder for all items? I'd need your feedback for I've worked very hard to offer you this template and it's pointless if you cannot use it. So please, while posting comments, give as much details as possible as it's the only way I can improve it.
