when i export my base to html
movies are in diferent position
like:
no.21
no.2
no.12
no.4
how can i fix this?
how export in alphabetical order to?
export to html:
You mean the files when you see them in Windows Explorer ?
For the moment numbers are output like that and that can't be changed, sorry
(note that Windows XP will sort there files in the "natural" order, i.e. it sees that they end by numbers even if there is no "0" in front of small numbers)
If you mean the order on the HTML page, there are sort options at the bottom of the Export window.
