wILL IT IMPORT MOVIE NAMES FROM cd/dvd
gabbar595
Post by gabbar595 »
I have about 300 DVDs each having 4-5 movies (,avi). So entering names manually can be quite a task.
Will AMC import filenames from the DVD
What do you mean by "entering the names"?
If you want to have file name as title, there is an option in program's preferences that you can enable for that (on media file importation page of the preferences window).
But you still have to import the files one by one.
Else there are some programs made by other users for importing many files, e.g.: viewtopic.php?t=3474
