XML export fields
bonienl
XML export fields
Post by bonienl »
When doing an XML export the corresponding file does not have all possible fields included. I am missing for example the "director" and "videobitrate/audiobitrate" fields. Since I am using these fields I need them to be included.
I did not find any option to control which fields will be exported into the XML file as can be done for other exports (example CSV). Is this something fixed or am I overlooking something?
The XML File from 'export' is the same as the XML file from 'save as', so it contains all available fields and can be opened as AMC database file. The fields will only be visible on the XML file if they are filled with values on your database.
bonienl
Post by bonienl »
Bad4u, thanks for your answer. This is indeed what is happening.
