Error message
rich110
Error message
Post by rich110 »
I have imported about 400 movies in ANT. I am trying to export the catalog as an XML file for use in MediaPortal (using MyFilms plugin).
When I try "Save as" XML file the program asks me if I want to save the pictures as individual files - I click on OK.
But... then I get an error message that says:
Cannot create file"". The system cannot find the path specified
I have been using the ANT database in this way for ages but this is the first time I've ever seen this error message. I recently started a new database and that is when this started. Am I missing some simple option setting?
Cheers
Rich
Can you reproduce that problem in few steps from an empty catalog? Or can you send me the AMC file if it is not too big?
