problem with resizing cover within floating window
biker72
Post by biker72 »
Hi
I have the flowwing problem\styling issue:
I designed a custom layout for the main page (movielist)
On the screen I use a floating Image-window (undocked).
In the preferences I selected the option "fit picture in window".
When I use a picture larger then the picture-window it isn't properly fitted in the window. I can only see part of the picture.
However, when I resize the picture window by even one pixel the cover is resized to fit the window. So the resize event itself seems to work fine.
When I now select a different movie and reselect the first one the cover again is larger then the picture window.
Tried the following:
* saving in between the actions.
* uncheck "fit picture in window" en recheck it (while restarting AMC)
It seems having somethnig to do with the docking part, because when I select "Docked", the resize works fine.
I use version 3.5.1.0 (2007-09-22)
Thanks in advance.
Thanks for the info, I'll check that for the next release.
biker72
Post by biker72 »
Hi Antoine,
I know your very busy but I was wondering if this issue is still on your radar?
(I installed the latest version 3.5.1.1)
Thnx,
Dennis
Yes, it is still in the bug list
crowley
Post by crowley »
I do have this problem, too.
It happened after I converted my catalog from amc to xml (and all the images are now "external files").
But I cannot reproduce this o_O
