Are you still working ?
Hawkie
Post by Hawkie »
Hi !
It's been a long time since you've released a new version of Ant Movie Catalog..there are many features to be implemented. Are you still working on this program ? Would you consider making it open-source ?
Long time ? I released an upgrade that corrects two bugs few days ago.
And the latest new version was only a little more than one month ago.
3.2.1 : 26 / 02
3.3.0 : 25 / 05
we are 07 / 07
So this is not so long ago ;)
I do not have lot of time to work on the program (I work in the "real life", so I cannot spend all my days to work on it), but I still work on it.
After version 3.3.0 I worked on other things (e.g. make my site XHTML compatible).
I will maybe make it open source when I do not want to continue it, or when I really do not have time. At least not before I have finished to add what I really want to add before releasing the source code to others.
Maybe that version 3.5 or 3.6 will be open source. Or version 4.
I do not know yet.
