pocet PC/ windows mobile
njdvdguy
Post by njdvdguy »
Hi all,
I am curious, has anyone , or is there a way to look at my AMC file on a pocket PC, windows mobile, Windows CE operating system?
thanks for any info
One solution is to export to CSV, open that in Excel and save to XLS format. Then that XLS file can be put on the PocketPC.
You can also convert the XLS file with this: http://doobsexporter.sourceforge.net/doobs4excel/
It is also possible to use some HTML templates, e.g.:
viewtopic.php?t=1597
njdvdguy
Post by njdvdguy »
thanks Antp, i'll read up and give it a go
