Is there a problem with the Amazon script? For every movie I try to d/l info for, it says "movie not found".
thanks.
Issue with Amazon script?
yeah, i have the same problem. The script looks like this:
program Amazon;
StringUtils1;
AmazonPage: TStringList;
THolder, MovieName : string;
LineNr, I: Integer;
function GetToken(aString, SepChar: String; TokenNum: Integer):String;
Token : string;
StrLen : Integer;
TNum : Integer;
TEnd : Integer;
StrLen := Length(aString);
TNum := 1;
TEnd := StrLen;
while ((TNum <= TokenNum) and (TEnd <> 0)) do
TEnd := Pos(SepChar,aString);
if TEnd <> 0 then
Token := Copy(aString,1,TEnd-1);
Delete(aString,1,TEnd);
TNum := TNum + 1;
Token := aString;
if TNum >= TokenNum then
GetToken := Token;
GetToken := '';
function AsinParse(Line : string): string;
Result := GetToken(GetToken(Line,'.',2),Chr(34),1);
// ***** analyze the page containing movie information *****
procedure AnalyzeMoviePage(AsinNr: string);
MovieURL, PageText, Value, Value2: string;
LP: integer;
GetPicture('http://images.amazon.com/images/P/' + AsinNr + '.01.LZZZZZZZ.jpg');
MovieURL := 'http://www.amazon.com/exec/obidos/tg/detail/-/' + AsinNr + '/';
PageText := GetPage(MovieURL);
// URL
if CanSetField(fieldURL) then
SetField(fieldURL, MovieURL);
// DVD Title & Year
if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
Value := TextBetween(PageText, '<title>', '</title>');
LP := LastPos('(', Value);
Value2 := Copy(Value, LastPos('(', Value) + 1, 4);
SetField(fieldYear, Value2);
Value2 := TextBetween(Value, 'Amazon.com: DVD: ',' ('+ Value2);
HTMLDecode(Value2);
SetField(fieldOriginalTitle, Value2);
//Editorial Review
if GetOption('GetReview') > 0 then
Value := TextAfter(PageText, '<a name="amzn-reviews">');
if Value <> '' then
Value := TextBetween(Value, '<b class=h1>Editorial Reviews</b>', '<a name="cust-reviews-section">');
Value := StringReplace(Value, #13#10, ' ');
HTMLRemoveTags(Value);
HTMLDecode(Value);
Value := Trim(Value);
while Pos(' ', Value) > 0 do
Value := StringReplace(Value, ' ', ' ');
while Pos(#13#10, Value) = 1 do
Delete(Value, 1, 2);
case GetOption('GetReview') of
1:
if CanSetField(fieldDescription) then
2:
// Director
Value := TextBetween(PageText, '<b>Director:</b>','</a><br>');
HTMLDecode(Value);
SetField(fieldDirector, Trim(Value));
// Producer
Value := TextBetween(PageText, '<b>Studio:</b>','<li>');
Value := StringReplace(Value, #13#10, '');
SetField(fieldProducer, Trim(Value));
// Length
Value := TextBetween(PageText, '<b>Run Time:</b>','<br>');
SetField(fieldLength, Trim(Value));
// ***** beginning of the program *****
if CheckVersion(3,5,0) then
AmazonPage := TStringList.Create;
AmazonPage.Text := GetPage('http://www.amazon.com/exec/obidos/search-handle-url/index=dvd&field-title=' + StringReplace(UrlEncode(GetField(fieldOriginalTitle)),'+', '%20'));
if FindLine('unable to find exact matches',AmazonPage,1) <> -1 then
ShowMessage('Movie "' + GetField(fieldOriginalTitle) + '" not found.');
if FindLine('Amazon.com: DVD:',AmazonPage,1) <> -1 then
LineNr := FindLine('<input type="hidden" name="asin.',AmazonPage,1);
THolder := AsinParse(AmazonPage.Getstring(LineNr));
AnalyzeMoviePage(THolder);
if (FindLine('Below are results for',AmazonPage,1) <> -1) OR (FindLine('All results',AmazonPage,1) <> -1) OR (FindLine('Most popular results for',AmazonPage,1) <> -1) OR (FindLine('Results for',AmazonPage,1) <> -1) then
i := 1;
PickTreeAdd('Movies','');
while (i <= AmazonPage.Count-1) do
THolder := AmazonPage.GetString(i);
HTMLRemoveTags(THolder);
if (Pos('/exec/obidos/ASIN/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) then
PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',5));
if (Pos('/exec/obidos/tg/detail/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) and (Pos('http://www.amazon.com',AmazonPage.GetString(i)) = 0) and (Pos('In-store Pickup',AmazonPage.GetString(i)) = 0) then
PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',7));
i := i + 1;
if PickTreeExec(THolder) then
Today I released a new amazon script, you will find here: viewtopic.php?t=3932
It features a lot more imports and options and should not be broken when amazon websites' layout changes again.. besides it's very fast. Maybe you want to give it a try ?
