Bigger Font
downe
Bigger Font
Post by downe »
Why is font size so small, it would be better to have option to increase font size in all fields, it is to small.
And, one more thing, it would be nice to get information of music composer and scenario from imdb script.
Font size is the normal one, as the one by default in other applications :??: (and the program follows Windows font size if you change it in the advanced display properties).
For the IMDB script, some extra information are available be changing the script options (the list on the right of the script window), I do not remember if the music composer & scenario are amongst these.
