Viewing Big Covers/Images in the Catalog
imposslimbo
Post by imposslimbo »
When you view really big covers or images in the catalog, it resizes them down to be really small. Is there a way to turn off the resize? Or maybe adjust it some way?
Thank you
It resizes pictures to fit in the window, but you can disable that in the Preferences, on the movie information page (if I remember well - it is maybe on another page)
When you click on the picture it opens a window which itself is maybe resized to window screen, though that I do not remember exactly what is done: I remember that I made changes in that after some user requests.
imposslimbo
Thanks for the answer. Yes there was a setting for resizing picture to fit window, it was on the Movie Information section like you said. However, that did not change the picture being resized in the pop up window. Like you said, you have addressed this issue at user requests so I guess I have to finally update to the new version to get this feature. I have been using an old version for a long time both because it gets the job done for me and because I'm too lazy to update.
