only extracts the duration of the first .avi file
raguchi
Post by raguchi »
When you're importing video information from several .avi files (CD1, CD2, etc...), it only extracts the length of the first part, it doesn't add the diferent durations of all the files.
i'm using this version:
Información
moviecatalog.exe : versión 3.5.1.0 (creado el 22/09/2007 11:46:38)
AMCExchange.dll : versión 1.1.0.1 (creado el 22/09/2007 11:47:54)
AMCReport.exe : versión 1.0.2.2 (creado el 15/01/2005 17:13:56)
MediaInfo.dll : versión 0.7.5.2 (creado el 16/08/2007 17:25:18)
strange, I'll check that, thanks ;)
raguchi
Post by raguchi »
Actually, it keeps the duration of the last avi file (without adding the previous values).
i've tried another version and it works OK:
Información
moviecatalog.exe : versión 3.5.0.2 (creado el 29/05/2005 11:51:40)
AMCExchange.dll : versión 1.0.1.6 (creado el 26/06/2004 23:39:22)
AMCReport.exe : versión 1.0.2.2 (creado el 15/01/2005 16:13:56)
MediaInfo.dll : versión 0.6.0.0 (creado el 18/05/2005 22:45:58)
see you!
In that other version was it using Media Info or not? As I changed the default behavior of the option to use Media Info or internal engine for AVI files.
I actually already had that in my bug list. Anyway it will be fixed for the next release.
raguchi
Post by raguchi »
OK, It's checked out: Both versions I've posted work OK with the internal engine, and both don't work OK with the Media Info.
i'll use internal engine from now on.
thanks!! ;)
