UPDATE SCRIPTS not working
Roadking
Post by Roadking »
OS Win 10. Update Script comes with the error message
Cannot create file ...
. My opinion: the
http:\\update.antp.be
is wrong, because all my directory and file names are correct and existent.
Re: UPDATE SCRIPTS not working
Sorry for late reply.
If it cannot create the file, I guess it does not have a write-access to the folder.
To install the program, did you use the installer or did you use the .rar file (portable version) to place it manually somewhere on your computer? If so, in which folder?
Otherwise you can manually update the scripts files by downloading the files from http://update.antp.be/amc/scripts/ and placing them in the Scripts folder, replacing existing files.
