I want to download the code and make this change, but i ask before because maybe someone it's already doing this job.
I want to add support for multiple genre, because right now, when you import data from IMDB only the first genre is saved and all the others not.
Thanks.
Support for Multiple genre
If you are talking about the current IMDB script, first make sure that you are using latest version 3.23 (you can see version number on the left bottom corner of scripts listing page).
If so, check script option "MultipleValuesCategory", it should be set to "1" or "2", then all values for genre should be imported to category field (maybe you have set it to "0").
I did some short tests and it saves all genres listed on the movie page. If you still have problems please name a film you have problems with, perhaps there's a small bug somewhere.
rpm
