No movie found
sh50
No movie found
Post by sh50 »
HI
When I try to get information from IMDB using a script from internet
I get the message "No movie found". If anywone have an answer I will be very happy.
Make sure you use the latest IMDB script version 3.23 (to check this, go to the scripts listing, mark the IMDB script and look at left side on the bottom of the page). Current version 3.23 seems to work for me.
You can download latest script version from http://update.antp.be/amc/scripts or simply use the script "UPDATE_SCRIPTS" for this, so you can update the script without leaving AMC.
Solved ;)
