Subnumbers
nixon
Subnumbers
Post by nixon »
Hi
I've been using antp for some time now. Great program btw :grinking:
Because my stack of Xvid's grows alot, i was thinking to replace my Xvid (cd's) to Xvid (DVD's). Mulitple avi's on 1 DVD.
I made a list which has 1 number singed to 1 movie.
But if i have more then 1 movie on 1 dvd, i can't number everything like it should be.
Is is possible to number dvd 50 as, 50a, 50b, 50c,... or 50.1,50.2,... with all other futures? (import information of scripts,...)
Or can it be introduced?
I do not know yet how I will handle that in futures versions.
Currently I give to the DVD the number of the first movie that it contains, and put that number in the "media label" field of the six movies that it contains.
So I can then group by media label (there is also an option in loans window to handle that)
nixon
Post by nixon »
Works perfect. Thx
I do have to edit everyting :wow:
