OFDB Script Fix
DarkS
OFDB Script Fix
Post by DarkS »
Hi
Here is the fixed version 1.0.4 of the OFDB script. It fixes following bugs.
- Parse correct movie address (with no onmouseover part)
- Import description fix. I've described this problem here already, but since the script wasn't updated yet I've included this fix in the new version.
Authors=Fabian Filipczyk / fixed 20061222 bad4u / fixed 20070311 yeti
Title=OFDb
Description=Online-Filmdatenbank (OFDb) import with small picture (DE)
Site=http://www.ofdb.de
Language=DE
Version=1.0.4
Requires=3.5.0
Comments=
ReformatDescription=1|1|0=Do not reformat. Add the description as on OFDB|1=Reformat the description. Remove all Linefeeds and make a long flow text.
1.0.4 (02/12/2007) by DarkS
- Fix: Parse correct URL for movie address (with no onmouseover part)
- Fix: if the movie description on the first ofdb page has no [mehr]-Link, the
  script adds an empty string only
1.0.3 (06/11/2007) by yeti (yeti@gmx.info)
- Fix: if the actors list on the first ofdb page have no [mehr]-Link, the
  script adds an empty string only (thx DarkS)
1.0.2 (03/06/2007) by yeti (yeti@gmx.info)
- Chg: Code cleanup
- New: Option to import the description as is, include all line feeds.
  Standard is reformat as before.
- Fix: The last change in actors loading from the cast/crew details page
  reads the crew names too :( Hope I've finally fixed this now.
1.0.1 (03/04/2007) by yeti (yeti@gmx.info)
- Chg: Added stringUtils1-Lib and removed FindLine(), Code cleanup (not completed yet)
- Fix: If the actor-name in the details view is clickable to view the actors
  profile, the name was not imported.
1.0.0 (03/03/2007) by yeti (yeti@gmx.info)
- Fix/Chg: Ratingimport changed to 2 digits (rounded)
  Rating 6.49 -> Old: 7 -> New: 6.5
- Chg: Removed old code
- New: Version number 1.0.0 added for better distinction between versions
program OFDB_DE;
  stringUtils1;
  CRLF = #13#10;
  if pos('<title>OFDb - Suchergebnis', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
    LineNr := FindLine('<b>Titel:</b>', Page, 0);
    if LineNr > 0 then
      PickTreeAdd('Filme :', '');
         AnalyzePage(Address);
  Line, Temp, Value: string;
  LineNr, LineNrTmp, IntValue: Integer;
  BeginPos, EndPos: Integer;
  // Picture
  LineNr := FindLine('images/film/', Page, 0);
  if LineNr > -1 then
    Value := TextBetween(Line, '<img src="', '" alt=');
    if Value <> '' then
      Temp := 'http://www.ofdb.de/' + Value;
      GetPicture(Temp);
  // Original Title
  LineNr := Findline('Originaltitel:', Page, 0);
  if LineNr > -1 then
    HTMLRemoveTags(Line);
    Line := Trim(Line);
    if Line <> '' then SetField(fieldOriginalTitle, Line);
  // Translated Title
  LineNr := Findline('sans-serif" size="3"><b>', Page, 0);
  if LineNr > -1 then
    Line := Trim(Line);
    if Line <> '' then SetField(fieldTranslatedTitle,Line);
  // Country
  LineNr := Findline('Herstellungsland:', Page, 0);
  if LineNr > -1 then
    LineNr := LineNr + 3;
    Line:= Page.GetString(LineNr);
    Delete(Line, 1, Pos('<a', Line) - 1);
    Line := StringReplace(Line, '<br><a', ', <br><a');
    SetField(fieldCountry, Line);
  // Year
  LineNr := Findline('Erscheinungsjahr:', Page, 0);
  if LineNr > -1 then
    Value := TextBetween(Line, '">', '</a></b>');
    if Value <> '' then SetField(fieldYear, Value);
  // Category
  LineNr := Findline('Genre(s):', Page, 0);
  if LineNr > -1 then
    Value:= '';
    LineNr := LineNr + 2;
      Line := TextAfter(Line, '<a');
      Temp := TextBetween(Line, '">', '</a><br>');
      if Temp <> '' then Value := Value + ', ' + Temp ;
    until (Temp = '');
    Value:= Copy(Value, 3, Length(Value) - 1);
  // Actors
  LineNr := Findline('Darsteller', Page, 0);
  if LineNr > -1 then
     if Pos('">[mehr]', Line) > 0 then
       BeginPos := Pos('<a href="view.php?page=film_detail', Line) + 9;
       EndPos := Pos('">[mehr]', Line);
       GetOFDBActors(Value);
       SetField(fieldActors, Line);
  // Director
  LineNr := Findline('Regie', Page, 0);
  if LineNr > -1 then
    Value := '';
    SetField(fieldDirector, Line);
  // Description
  LineNr := Findline('<b>Inhalt:</b>', Page, 0);
  LineNrTmp := LineNr;
  if LineNr > -1 then
    LineNr := Findline('<a href="view.php?page=inhalt', Page, 0);
    if LineNr > -1 then
    begin //"[mehr]" part exists
      BeginPos := Pos('<a href="view.php?page=inhalt', Line) + 9;
      EndPos := Pos('"><b>[mehr]', Line);
      GetDescriptions(Value);
    begin //No "[mehr]" part exists
      Line := Page.GetString(LineNrTmp);
      Value := TextBetween(Line, '<b>Inhalt:</b>', '</p></font></td>');
      SetField(fieldDescription, FullTrim(Value));
  // Rating
  LineNr := Findline('<br>Note:', Page, 0);
  if LineNr > -1 then
    BeginPos := Pos('<br>Note:',Line) + 10;
    // I had to add 0.1 here to make the rounding more precise
    Value := IntToStr(Round((StrToInt(Copy(Line, BeginPos+2, 2), 0) + 0.1) / 10));
    if StrToInt(Value,0) > 9 then
      Value := IntToStr(StrToInt(StrGet(Line, BeginPos),0) + 1) + '.0'
      Value := StrGet(Line, BeginPos) + '.' + Value;
    SetField(fieldRating, Value);
procedure GetOFDBActors(Address: string);
  Line,Temp, Value: string;
  LineNr, EndLine: Integer;
  Page.Text := GetPage('http://www.ofdb.de/'+Address);
  if LineNr > -1 then
    Value:= '';
    EndLine := FindLine('/table', Page, LineNr);  // Find the end of the cast-table
      LineNr := Findline('<a href="view.php?page=', Page, LineNr + 1);
      if LineNr >= EndLine then LineNr := -1;     // Cast-Table ended, leave loop
      if LineNr > -1 then
        Delete(Line, 1, pos('<a href="view.php?page=', Line) + 22);
        Temp := TextBefore(Line, '=', '');
        if (Temp = 'person&id') Or (Temp = 'liste&Name') then
          Temp := TextBetween(Line, '">', '</a>');
          HTMLRemoveTags(Temp);
          if Temp <> '' then Value := Value + ', ' + Temp;
    until (LineNr < 0);
    Value:= copy(Value, 3,length(Value)-1);
    SetField(fieldActors, Value);
procedure GetDescriptions(Address: string);
  Line, Value, Temp: string;
  Reformat: Boolean;
  Value := '';
  if GetOption('ReformatDescription') = 1 then Reformat := True else Reformat := False;
  Page.Text := GetPage('http://www.ofdb.de/' + Address);
  LineNr := FindLine('Eine Inhaltsangabe von', Page, 0);
  if LineNr > -1 then
    Line := TextAfter(Line, '</a></b><br><br>');
    while (Pos('<br />', Line) > 0) do
      Temp := TextBefore(Line, '<br />', '');
      if Not Reformat then
        Value := Value + Temp + CRLF;
        if Temp <> '' then Value := Value + Temp + ' ';
      LineNr := LineNr + 1;
    Value := Value + TextBefore(Line, '</font></p>', '');
  MovieTitle, MovieAddress, CutMark, CutMarkAddress: string;
  StartPos, EndPos: Integer;
    CutMark := '">';
    CutMarkAddress := '" ';
    StartPos := Pos('<a href="view.php?page=film&fid=', Line);
    if StartPos = 0 then
      StartPos := Pos('<a href=''view.php?page=film&fid=', Line);
      CutMark := '''>';
      CutMarkAddress := ''' ';
    if StartPos > 0 then
      Delete(Line, 1, StartPos + 8);
      MovieAddress := TextBefore(Line, CutMarkAddress, '');
      MovieTitle := TextBetween(Line, CutMark, '</a>');
      HTMLRemoveTags(MovieTitle);
      if (MovieAddress <> '') And (MovieTitle <> '') then
        //MovieAddress := MovieAddress + '&full=1';
        PickTreeAdd(MovieTitle , 'http://www.ofdb.de/' + MovieAddress);
        StartPos := -1; // Error - Leave the Loop
  until (StartPos < 1);
  if CheckVersion(3,5,0) then
    if Input('OFDb', 'Bitte Titel eingeben :', MovieName) then
      AnalyzePage('http://www.ofdb.de/view.php?page=suchergebnis&SText='+UrlEncode(MovieName)+'&Kat=All');
You might have to set new variable "CutMarkAddress" for this part of the code, too :
      CutMark := '''>';
It is neccessary if there are pages that use two ' instead of one " for a link, but unfortunatly I do not have an example page to test this.
DarkS
Post by DarkS »
You are right. I have overlooked this part.
I've updated the script in the first post with a new line.
yeti
Post by yeti »
Thanks for your Update. I had no time to read the forum in the last months. And because I've no problems with the version 1.0.3, I don't update the script myself.
Greets,
yeti
Here's a new version (1.0.5) of OFDB script :
http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
- Fix: some films have been missing on the results list (i.e. 'Am Tode vorbei')
- Fix: description import broken for some films (i.e. 'Cashback' - one version worked, one not)
They (currently) use multiple formats for links on result lists and movie detail pages, if you find more problems please post the movie name here..
raistlin2k
another not working movie :(
Post by raistlin2k »
First of all, thanks for your fix!
Its working for most movies!! :grinking:
But it doesn't work on "In & Out", a movie from 1997.
The movie is available on OFDB, but i get no results with AMC.
Hope you can fix this!
Thanks in advane,
Raist
Re: another not working movie :(
raistlin2k wrote:But it doesn't work on "In & Out", a movie from 1997.
This bug is not caused by the script, it is caused by the function URLEncode, that does not translate the '&' into '%26'. Maybe antp can fix this or is it wanted/not possible ?
Most scripts will work if you just search for 'in out', but OFDb doesn't find correct movie. Nevertheless I did a short workaround on the scripts OMDb and OMDb+IMDb using StringReplace.
OFDb 1.0.6: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
OFDb - IMDb 1.3.3: http://www.bad4u.741.com/full/OFDb%20-% ... 8DE%29.ifs (copy link into a NEW browser window !)
Good question... I am not sure if it is made on purpose or if it is a bug. I'll write it in my to-do list to check.
Thanks ;)
raistlin2k
thanks bad4u, works now :) :grinking:
OFDb 1.0.7: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
Fixed broken picture import.
OFDb 1.0.8: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
Fixed special characters import (UTF8).
OFDb 1.0.9: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
Fixed broken description import (from additional page).
OFDb 1.0.10: http://www.bad4u.741.com/full/OFDb%20%28DE%29.ifs (copy link into a NEW browser window !)
Fixed broken description import for special cases (when short description exceeds one row it could not find link to complete summary).
antp wrote:Good question... I am not sure if it is made on purpose or if it is a bug. I'll write it in my to-do list to check.
Beter late than never: the reason why & is not converted is because I use a function called ParamsEncode, which (as its name says) is dedicated to parameters encoding, and it supports that the string given is a list of parameters, not especially one parameter.
So indeed converting & would be dangerous, as in some cases it does not have to be converted.
I do not know what would be the best solution in this case. Maybe a second function which also encodes the & ?
antp wrote:I do not know what would be the best solution in this case. Maybe a second function which also encodes the & ?
:) I'd say, it depends on how much work this would be. The StringReplace workaround works for the ofdb script, not sure if it would make sense to add support for the & on other scripts, too. I personally did not need it yet.. but didn't test some more scripts for their behaviour on using the & symbol on movie names.
It would probably fail in most of the scripts, as what follows the & will be part of a separate parameter for the site.
