Merge two or more amc files in only one
Murnau_Vs_Buñuel
Post by Murnau_Vs_Buñuel »
Hi, is possible merge two or more amc files in only one?
I have 3 differents amc files and i want merge these to work in only one.
what is the better way? thanks.
"File -> Import -> AMC" should work fine for you, it works for .amc and .xml file format and imports a second catalog into the first one
(turn off "Allow dublicate numbers" if you want to add new numbers for imported movies) :)
Murnau_Vs_Buñuel
this seems work fine, thanks! :grinking:
