Problem with Scripting
r32
Post by r32 »
Hi!
If I change the modifiable fields in scripting, the settings are not saved.
Same issue if i use a script to get information for a movie by imdb.
I disable original title and translate title, but this settings are not saved.
I use the newest offical version of movie catalog on a vista pc.
Anyone has a idea?
best regards
r32
These are saved for each script, but only when the script is run, maybe this was the problem?
