Picture stretch error
kgytopi
Post by kgytopi »
Hello Antoine!
Great work on Ant Movie Catalog, it is my favorite software!
I found a small bug in version 3.5.1 beta?
Hi, kgytopi
Budapest, Hungary
Hi.
1. Your AMC version 3.5.1 should not be beta anymore, else you should download latest release version ;)
2. Have you tried changing option "Fit picture in window" ? You find it on "Tools -> Preferences -> Movie information" ? Just a little bit confused about the missing scroll bars in your picture..
What format is the image?
Does it happens only with that one? Can you send it to me?
kgytopi
Stretch error
Post by kgytopi »
Hi.
Version 3.5.1.0 207.09.22 now works fine :)
(I have downloaded it again)
Thanx
kgytopi
