Hello,
i am trying to import hundreds of divx.
I got the nice tool mvlistgui which produces a csv file to import into AMC.
The problem is that the file name is copied to the field title.
when sending scripts, the file name is never recognised in all movie database so it return an error which is normal.
In fact the file name should be translated to original title based on a remote divx file name database (if it exists).
Opensubtitle.org is not very far. With OSDB protocol it recognized the source file and after some hash calculation it will identify the file then give the ability to download the subtitle.
It would be nice to have something like this.
Use a script which will poll opensubtittle then return the tittle !
thx for your feeback on this.
Script to get tittle based on divx tittle
