Send to -> Doesnt work as aspected
wildpash
Post by wildpash »
when you multi select filenames (via Explorer) and send them thru 'send to' - contextmenu of explorer to Renamer.exe, no Filename is listed in the Filelist of Ant Renamer.
This is not a bug as nothing was made to handle that.
Currently it only works with one item (e.g. the folder then).
You can also send only first file, and once the program is open add the other files by drag & drop.
