Mod problem
enverge
Mod problem
Post by enverge »
I am sorting a read-only dumbed down version that will autoplay from a cd.
I have omitted the fields I do not need but have this 'M' which I cant get rid of arrrrggggghhhh can anyone help?? Its in the File Size if that helps
It is probably "LSizeUnit"
Alternatively, you can switch to bytes for unit display, which will make the "M" prefix disappear.
enverge
Post by enverge »
sorted - cheers :)
