export jpg file inside sql file
shadowbikes
Post by shadowbikes »
Maybe in a next release, the possibility to export the jpg inside the sqlfile.
rene
It could be, but it would make a quite big SQL file for people that have large images. As images would have to be encoded in a text form, that will generate a file even bigger than the catalog itself.
