AMV freezes when ordering list with covers active
cianoz
Post by cianoz »
As in the title, if you click on left panel to order by Title and you have the covers shown the program go into a "freezed" status, and it become totally unusable.
I'm using AMC 3.5.1 on Windows XP SP2.
The problem does not occurs systematically but almost always.
If you disable the covers every ordering operation is OK.
Most of the freezing problems occured because of Nvidia drivers (but I never could reproduce the problem despite the fact that I also have a Nvidia-based video card).
If you have such video card, maybe it will be solved if you disable the "Nview Desktop" feature in display properties -> advanced -> nvidia
cianoz
Post by cianoz »
You were right!
In effect I have a Nvidia graphic card and the problem was that "Nview Desktop", once disabled it the problem has gone.
Thank you and my compliments.
