update Todoenvideo(AR) v 1.01 to 1.03
legrad
Post by legrad »
Añadidos campos: NºDiscos, Lenguaje, Subtitulos y Resolución
Authors=Legrad
Title=Todoenvideo(AR)
Description=
Site=www.todoenvideo.com.ar
Language=ES
Version=1.03
Requires=3.5.0
Comments=
License=
program Todoenvideo;
MovieURL: string;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
InitialPos: Integer;
if InitialPos = 0 then
result := ''
InitialPos := Pos(EndTag, S);
result := S
Delete(S, 1, InitialPos + 1);
n,len, tag: Integer;
c: char;
t: String;
tag := 0;
t := '';
len := length(s);
for n :=1 to len do
c := Copy(s,n,1);
if c = #9 then
c := ' ';
if(tag=1) then
if(c='>') then tag := 0;
continue;
if(c='<') then
tag := 1;
continue;
t := t + c;
s := t;
result := t;
strPage, MovieAddr, MovieTitle,MovieTitle1, MovieDate, MovieID, Movie: string;
BeginPos, EndPos: Integer;
BeginPoss, EndPoss: Integer;
strPage := GetPage(Address);
BeginPos := Pos('InstanceBeginEditable name="main"', strPage);
if(BeginPos > -1)then
Delete(strPage, 1, BeginPos);
BeginPos := Pos('<br><a href="pelicula.php?id=', strPage);
EndPos := 1;
MovieId := Copy(strPage,+29, EndPos-29);
MovieAddr := 'http://www.todoenvideo.com.ar/pelicula.php?id=' + MovieId;
BeginPoss := Pos('"pelisTitulo"><strong>',strPage);
EndPoss := Pos('</strong></span>', strPage);
HTMLDecode(MovieTitle);
MovieTitle := TextBetween(MovieTitle ,'<strong>', '</strong>');
MovieTitle := AnsiLowerCase(MovieTitle);
MovieTitle := AnsiUpFirstLetter(MovieTitle);
BeginPos := Pos('class="pelisTexto"><strong>',strPage);
EndPos := Pos('</strong></a>', strPage);
MovieTitle1 := Copy(strPage,BeginPos, EndPos);
MovieTitle1 := TextBetween(MovieTitle1 ,'<strong>', '</strong>');
MovieTitle1 := AnsiLowerCase(MovieTitle1);
MovieTitle1 := AnsiUpFirstLetter(MovieTitle1);
SetField(fieldCategory, Trim (MovieTitle1));
PickTreeAdd(MovieTitle+' ('+MovieTitle1+')', MovieAddr);
BeginPos := -1;
PickTreeSort;
PickTreeExec(Address)
AnalyzeMoviePage(Address);
Item: string;
Comments: string;
Actors: string;
Directors: string;
Description: string;
Busca: integer;
Commments: string;
Description := '';
// URL
// Titulo traducido
LineNr := FindLine('width="3" height="8">', Page, 0);
Item := TextBetween (Line, '</span>', '</span></td>');
HTMLDecode(Item);
Item := AnsiLowerCase(Item);
Item := AnsiUpFirstLetter(Item);
// Titulo original
LineNr := FindLine('Titulo Original:</b>', Page, 0);
if LineNr <> -1 then
Item := TextBetween (Line, '"textoNormal">', '</span>');
HTMLDecode(Item);
// director
LineNr := FindLine('<b>Director:</b>', Page, 0);
if LineNr > 0 then
Item := TextBetween (Line, 'director&que=', '">');
HTMLDecode(Item);
// discos
LineNr := FindLine('<b>Discos</b>:', Page, 0);
if LineNr > 0 then
Item := TextBetween (Line, '<b>Discos</b>:', '<br>');
HTMLDecode(Item);
SetField(fieldDisks, Trim (Item));
// Resolucion
LineNr := FindLine('<b>Pantalla</b>:', Page, 0);
if LineNr > 0 then
Item := TextBetween (Line, '<b>Pantalla</b>:', '<br><b>');
HTMLDecode(Item);
SetField(fieldResolution, Trim (Item));
// Lenguaje
LineNr := FindLine('<b>Idiomas</b>: ', Page, 0);
if LineNr > 0 then
Item := TextBetween (Line, '<b>Idiomas</b>: ', '<br><b>');
HTMLDecode(Item);
SetField(fieldLanguages, Trim (Item));
// Subtitulos
LineNr := FindLine('<b>Subtitulos</b>: ', Page, 0);
if LineNr > 0 then
Item := TextBetween (Line, '<b>Subtitulos</b>: ', '<br><b>');
HTMLDecode(Item);
SetField(fieldSubtitles, Trim (Item));
// Productor
LineNr := FindLine('</a><br><b>Sello:</b> <span class=', Page, 0);
Item := copy(Page.Text, pos('</a><br><b>Sello:</b> <span class=',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'textoNormal">', '</span>');
Item := Trim(Item );
DeleteTags(Item);
HTMLDecode(Item);
// Reparto
LineNr := FindLine('search&tipo=interprete&que=', Page, 0);
Item := copy(Page.Text, pos('search&tipo=interprete&que=',Page.Text), length(Page.Text));
Item := TextBetween (Item, '">', '</a><br><br><b>');
DeleteTags(Item);
HTMLDecode(Item);
// duracion
LineNr := FindLine('Duración:</b> <span class="textoNormal">', Page, 0);
if LineNr > 0 then
Item := copy(Page.Text, pos('Duración:</b> <span class="textoNormal">',Page.Text),
length(Page.Text));
Item := StringReplace(Item , '´', '');
// año
LineNr := FindLine('Año de filmación:</b> <span class=', Page, 0);
if LineNr > 0 then
Item := copy(Page.Text, pos('Año de filmación:</b> <span class=',Page.Text), length(Page.Text));
HTMLDecode(Item);
// pais
LineNr := FindLine('<b>País de origen:</b> <a class=', Page, 0);
if LineNr > 0 then
Item := copy(Page.Text, pos('<b>País de origen:</b> <a class=',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'pais&que=', '">');
Item := StringReplace(Item , '/', ', ');
HTMLDecode(Item);
// sinopsis
LineNr := FindLine('<b>Sinopsis:</b> <span class=', Page, 0);
if LineNr > 0 then
Item := copy(Page.Text, pos('<b>Sinopsis:</b> <span class=',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'textoNormal">', '</td>');
HTMLDecode(Item);
// Calificacion:
LineNr := FindLine('<b>Calificación:</b> <span class=', Page, 0);
Item := copy(Page.Text, pos('<b>Calificación:</b> <span class=',Page.Text), length(Page.Text));
DeleteTags (Item);
Item := Trim(Item);
HTMLDecode(Item);
Comments := Comments + 'Calificación: ' + Item +#13#10;
// Editora:
LineNr := FindLine('<b>Editora:</b>', Page, 0);
Item := copy(Page.Text, pos('<b>Editora:</b>',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'editora&que=', '"');
DeleteTags (Item);
Item := Trim(Item);
HTMLDecode(Item);
Comments := Comments + 'Editora: ' + Item +#13#10;
// Estreno en video
LineNr := FindLine('<b>Estreno en video:</b>', Page, 0);
Item := copy(Page.Text, pos('<b>Estreno en video:</b>',Page.Text), length(Page.Text));
DeleteTags (Item);
Item := Trim(Item);
HTMLDecode(Item);
Comments := Comments + 'Estreno en video: ' + Item +#13#10;
// Caracteristicas del dvd
LineNr := FindLine('<b>Caracteristicas del dvd:</b>', Page, 0);
Item := copy(Page.Text, pos('<b>Caracteristicas del dvd:</b>',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'textoNormal"><b>', '</table>');
Item := StringReplace(Item , '<br><b>',#13#10);
DeleteTags (Item);
Item := Trim(Item);
HTMLDecode(Item);
Comments := Comments + 'Caracteristicas del dvd: '+#13#10 + Item ;
// Caratula
LineNr := FindLine('<img src="/imagespelis/', Page, 0);
if LineNr > 0 then
Item := copy(Page.Text, pos('<img src="/imagespelis/',Page.Text), length(Page.Text));
Item := TextBetween (Item, '<img src="/imagespelis/', '" width=');
HTMLDecode(Item);
GetPicture ('http://www.todoenvideo.com.ar/imagespelis/'+Item);
Input('Todoenvideo', 'Buscar:', MovieName);
if(GetOption('Sin resultado') = 0) then Input('Todoenvideo', 'Buscar:', MovieName);
AnalyzePage('http://www.todoenvideo.com.ar/peliculas.php?tipo=titulo&f=vhs%2Fdvd&que=' +
UrlEncode(MovieName));
slasher
Post by slasher »
Como siempre, muchas gracias legrad!!! :grinking:
