New script Todoenvideo(AR)ES v1.0
legrad
Post by legrad »
Nuevo script de la pagina www.todoenvideo.com.ar
Authors=Legrad
Title=Todoenvideo
Description=
Site=www.todoenvideo.com.ar
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program Todoenvideo;
  MovieURL: string;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  strPage, MovieAddr, MovieTitle,MovieTitle1, MovieDate, MovieID, Movie: string;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('InstanceBeginEditable name="main"', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('<br><a href="pelicula.php?id=', strPage);
      EndPos := 1;
          MovieId := Copy(strPage,+29, EndPos-29);
          MovieAddr := 'http://www.todoenvideo.com.ar/pelicula.php?id=' + MovieId;
          BeginPoss := Pos('"pelisTitulo"><strong>',strPage);
          EndPoss := Pos('</strong></span>', strPage);
          HTMLDecode(MovieTitle);
          MovieTitle  := TextBetween(MovieTitle ,'<strong>', '</strong>');
          MovieTitle  := AnsiLowerCase(MovieTitle);
          MovieTitle  := AnsiUpFirstLetter(MovieTitle);
          BeginPos := Pos('class="pelisTexto"><strong>',strPage);
          EndPos := Pos('</strong></a>', strPage);
          MovieTitle1 := Copy(strPage,BeginPos, EndPos);
          MovieTitle1  := TextBetween(MovieTitle1 ,'<strong>', '</strong>');
           MovieTitle1  := AnsiLowerCase(MovieTitle1);
          MovieTitle1  := AnsiUpFirstLetter(MovieTitle1);
          SetField(fieldCategory, Trim (MovieTitle1));
          PickTreeAdd(MovieTitle+' ('+MovieTitle1+')', MovieAddr);
           BeginPos := -1;
    PickTreeSort;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Commments: string;
  Description := '';
  // URL
  // Titulo traducido
  LineNr := FindLine('width="3" height="8">', Page, 0);
  Item := TextBetween (Line, '</span>', '</span></td>');
  HTMLDecode(Item);
  Item  := AnsiLowerCase(Item);
  Item  := AnsiUpFirstLetter(Item);
  // Titulo original
  LineNr := FindLine('Titulo Original:</b>', Page, 0);
  if LineNr <> -1 then
    Item := TextBetween (Line, '"textoNormal">', '</span>');
    HTMLDecode(Item);
   // director
  LineNr := FindLine('<b>Director:</b>', Page, 0);
  if LineNr > 0 then
    Item := TextBetween (Line, 'director&que=', '">');
    HTMLDecode(Item);
  // Productor
  LineNr := FindLine('</a><br><b>Sello:</b> <span class=', Page, 0);
    Item := copy(Page.Text, pos('</a><br><b>Sello:</b> <span class=',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'textoNormal">', '</span>');
    Item  := Trim(Item );
    DeleteTags(Item);
    HTMLDecode(Item);
  // Reparto
  LineNr := FindLine('search&tipo=interprete&que=', Page, 0);
    Item := copy(Page.Text, pos('search&tipo=interprete&que=',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '</a><br><br><b>');
    DeleteTags(Item);
    HTMLDecode(Item);
  // duracion
 LineNr := FindLine('Duración:</b> <span class="textoNormal">', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Duración:</b> <span class="textoNormal">',Page.Text), length(Page.Text));
    Item  := StringReplace(Item , '´', '');
  // año
  LineNr := FindLine('Año de filmación:</b> <span class=', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Año de filmación:</b> <span class=',Page.Text), length(Page.Text));
    HTMLDecode(Item);
  // pais
  LineNr := FindLine('<b>País de origen:</b> <a class=', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>País de origen:</b> <a class=',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'pais&que=', '">');
    Item  := StringReplace(Item , '/', ', ');
    HTMLDecode(Item);
  // sinopsis
 LineNr := FindLine('<b>Sinopsis:</b> <span class=', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Sinopsis:</b> <span class=',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'textoNormal">', '<br>');
    HTMLDecode(Item);
  // Calificacion:
   LineNr := FindLine('<b>Calificación:</b> <span class=', Page, 0);
    Item := copy(Page.Text, pos('<b>Calificación:</b> <span class=',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Calificación: ' + Item +#13#10;
  // Editora:
   LineNr := FindLine('<b>Editora:</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>Editora:</b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'editora&que=', '"');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Editora: ' + Item +#13#10;
    // Estreno en video
   LineNr := FindLine('<b>Estreno en video:</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>Estreno en video:</b>',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Estreno en video: ' + Item +#13#10;
  // Caracteristicas del dvd
   LineNr := FindLine('<b>Caracteristicas del dvd:</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>Caracteristicas del dvd:</b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'textoNormal"><b>', '</table>');
    Item  := StringReplace(Item , '<br><b>',#13#10);
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Caracteristicas del dvd: '+#13#10 + Item ;
 // Caratula
  LineNr := FindLine('<img src="/imagespelis/', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<img src="/imagespelis/',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<img src="/imagespelis/', '" width=');
    HTMLDecode(Item);
     GetPicture ('http://www.todoenvideo.com.ar/imagespelis/'+Item);
Input('Todoenvideo', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Todoenvideo', 'Buscar:', MovieName);
   AnalyzePage('http://www.todoenvideo.com.ar/peliculas.php?tipo=titulo&f=vhs%2Fdvd&que=' + UrlEncode(MovieName));
gnbusetto
Por favor sube la version corregida, esta en otro topico
Post by gnbusetto »
En otro hilo esta la nueva version que arregle, tenia mal una letra.
gracias
