Multiple movie info import
Nodeity
Post by Nodeity »
Hey guys, first time user of Ant, this Q has no doubt been asked and answered, but I can't find the references. I have a large collection of MKV movies on my NAS, and I'd like to import them into Ant in bulk, but for the life of me I can't figure out how to get past the single movie import function. There must be a way to grab the info for more than one fill at a time, or it would take me weeks to import them all? If not, then is there a free cataloguer that can? Using 4.2.2.2.2 Thanks :)
Nodeity
Re: Multiple movie info import
Post by Nodeity »
Ok, I figured out how to import multiple files, strangely enough, I used ChatGPT, and it was correct! However, I still cannot get the IMDB info to come in, in bulk. Using the script, it seems to be trying, but just fails to actually do anything. This is a very frustrating program. :hum:
If you recently downloaded the program you may have to update the IMDb script.
When the sites change, the scripts have to be updated, but I don't update the full installer often enough.
At the top of the scripts list you'll find a script named "Update scripts": running that one shows you those that can be updated, select IMDb. Once done, close the scripts window and try running it again, it should work better.
