Numbers descending?
Jayvie
Numbers descending?
Post by Jayvie »
I like this program a lot, so I'm trying to use different templates to make my collection as I want it... Now, is there any way to sort the numbers descending, so that the newest is at the top?
Greetings
Inversing order is not possible currently. It is one of the big lack that I still haven't fixed (sorting thing is from early versions and I haven't changed it since).
Jayvie
Post by Jayvie »
Aha, no problem then ;)
Maybe you know an answer to this:
http://users.pandora.be/JayVie/dvdcollection.html
I have used this template, but now I want to add a scrollbar to the left frame, because you always have to scroll back up, when you want to watch one of the lower movies... How can I do this? Tried some things, but didn't quite work... If I have to post this elsewhere, no problem then
Actually for that there is another template. You have to see the files in template3.zip : movies.html is the frameset that includes both the list and movie detail pages, rather than having the list including the detail page like in the template that you used.
Jayvie
Post by Jayvie »
Oh really? I'll go and check that then, thanks!
