lost dates in xml format
acteo
Post by acteo »
Hello,
This is a problem i regularly encounter : adding dates disappear.
I most use xml file (with Mediaportal and the wonderful plugin Mes Films !). It is my default file on opening AMC (3502).
Fortuntaley, amc file is ok (unless i overwrite it with the xml one !).
Thanks for your help
I am not sure that it is related to the XML file, but in some cases the date picker field is bugged. It seems to be related to the checkbox in front of it but the occurrence of that bug seems more or less random.
If it really only happens with the XML, you should check if the date is stored in the XML or not, it would already allow to know if it is wrongly saved or wrongly read.
acteo
Post by acteo »
I'll check next times it happens.
I admit it occures randomly
elman
Post by elman »
Do you happen to use Vista? If so, what are your regional settings? It seems to me you might have similar problem as I do.
