I am using AMC and saving my catalog in XML format so that the MyFilms MediaPortal plugin can use the data.
I am finding that when I add new movies to the database, download the details for the movie using the IMDB script and then save the catalog, when I next open it, all the movies except for the new ones have lost the quotes surrounding the tag line in the movie description.
EG: prior to saving it might have been "A great movie" This movie is about something.
Once I add a new movie, download the data and save the database, when I next open it, it will instead be "A great movie" This movie is about something.
Currently I am manually going through and doing a search and replace to fix this. I was wondering if anyone knows why this may be happening and what a fix could be. As I said, this only happens to movies that were previously in the database. The newly added ones are fine.
I am using the latest IMDB script that the script updater finds and AMC 3.5.0.2.
Thanks.
Quotes in movie overview changing from " to "
I did not use XML format before, so I saved my database to XML, closed and reopened it, added a new film via IMDB 3.19, saved the database, closed program and reopened XML file.. I did this several times, but no problems here (AMC 3.5.0.2).
If only films are affected that have been in the database before, it should not be a scripting problem.
Maybe you could save a copy of your database to .amc format, and test if it shows same behaviour. What happens if you use other scripts ?
sxjxcx
I am having the same issue with Ant 3.5.0.2.
When I save my XML, quotes (") are turning into (") forcing it to show up as (") instead of (").
I can do a find-and-replace with a text editor to change (") to (") but next save they will all be replaced to (") again.
Is there something I am doing wrong or is this a bug?
whatisk
whatisk
Even though I was sure I had the latest version (and when I went into help, version it shows 3.5.0.2), the file I downloaded was slightly larger (by about 70kb).antp wrote:whatisk wrote:I redownloaded 3.5.0.2 and installed over the top and seems okay now.that's quite strange
When I installed that, all the versions reported were the same, but the initial test I did with some new movies didn't have the problem happen again.
I will keep an eye on it and if it happens again, try the beta version.
If you are talking about the installation file (amc_install.exe) or the archive (amc_full.rar) there might be differences in file size to your previous download, because of added/updated scripts and language files - programs' version 3.5.0.2 has not been changed in this case, as this was not a programs' update, just an update of the installation file.whatisk wrote:Even though I was sure I had the latest version (and when I went into help, version it shows 3.5.0.2), the file I downloaded was slightly larger (by about 70kb).
The size of the executable (MovieCatalog.exe) should always be the same for version 3.5.0.2 - as far as I know
