Stopped working! ahhhhhhhhhhhhhh
imakillu
Post by imakillu »
First let me say thank you for an awesome program! I have been using it for while and it just recently stopped working. I can drag/drop files and choose an action, then click go, but nothing happens!?! Either that or the just the first file in the drag/drop group gets changed and not the others. Weird. I tried shutting off my Antivi and Zonepro( both new for me so i dont know if they would effect it) The only other change i have made to my system is a backup drive and have Acronis running scheduled tasks to backup....
Any suggestions would be appreciated!
Thanks.
Ima
Thanks.
If you check the "log" tab/page, what does it contain for each file? Is there an error, a message saying that each file was renamed, or just nothing?
