Tab Order within Language file
pollewops
Post by pollewops »
Anyone know if it is possible to change the taborder within the language file, so using tabs the right flow of input boxes is followed ?
You can assign a number to the Taborder property of each field (the same way texts are assigned to Caption property), I think it would work.
sracer
Post by sracer »
Yes indeed. I just updated the AMC-MP3 language file with Taborder settings, and it does indeed work as expected. :grinking:
pollewops
Post by pollewops »
sracer wrote:Yes indeed. I just updated the AMC-MP3 language file with Taborder settings, and it does indeed work as expected. :grinking:
PERFECT !
:grinking:
